AC1237 primary pressure sensor signal
103,500 MILES • 2.0L • 6 CYL • AUTOMATIC
ABUARJAM
Is this ABS issue should be replaced?
Jun 27, 2021 at 7:33 PM
Good morning,
I need the code number in the correct format. It should begin with a C or B and 4 numbers after it. Then I can look up the code and narrow the area of failure for you.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
I attached a list of the sensors for the ABS system below. Let me know if you are referring to one of those sensors.
Jun 27, 2021 at 8:13 PM
