A/C work
44,000 MILES • 3.1L • 6 CYL • FWD • AUTOMATIC
JAYSINBAKO
  • 5 POSTS
I am replacing the A/C compressor on my Cutlass Ciera V6. I plan on putting a vacuum on the system after I install the new parts. My question is, will I need to replace the Pag oil that is already in my new compressor after I run the vacuum or will it stay in the unit and only need r134a once the vacuum is complete?
Apr 26, 2017 at 5:37 AM
CARADIODOC
  • 34,414 POSTS
The oil is added before you install the compressor because you may need to hold it a certain way so the fill plug or port is up. Many compressors come with the correct amount of oil already in them. Look for a tag that tells you if you need to add the oil yourself.
Be sure to pull the vacuum for at least a half hour, and even longer if the lines or new compressor were not sealed for more than a few hours.
Apr 26, 2017 at 6:59 AM
JAYSINBAKO
  • 5 POSTS
Thank you a ton. I have done plenty of mechanic work but this is my first dive into the A/C system. I appreciate the knowledge and quick response.
Apr 26, 2017 at 7:03 AM
CARADIODOC
  • 34,414 POSTS
You are welcome. I have a lot of people fooled with my "brilliance".
I will be out of town over the weekend at an old car show swap meet, but keep me informed of your progress.
Apr 26, 2017 at 8:52 AM
JAYSINBAKO
  • 5 POSTS
Final follow up. I've swapped everything over including accumulator and new compressor. Had it vacuumed and filled. Still didn't kick on. A little more research led me to the high pressure switch. That seemed to be the final piece to the puzzle which is a relief considering we can hit upwards of 110° during the summer here.
May 5, 2017 at 7:18 AM
CARADIODOC
  • 34,414 POSTS
I assume it's working now? If so, give yourself a pat on the back!
May 5, 2017 at 8:27 AM
