AC will not blow cold
2004 TOYOTA MATRIX
1 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
DANIEL1986
I replaced the compressor and vacuumed system down added Freon and now blows cold for only few seconds and then goes hot again. Any suggestions? And checked relay and fuse under dash.
Aug 18, 2018 at 12:03 PM
  • 110,240 POSTS
I need to know some general information. When it starts to blow cold, is the compressor no longer engaging? Can you tell me both the high and low side pressures and outside temperatures when you check? One last question. If the compressor is cycling properly, did you check to make sure the blend air door is not closing and not allowing the cold air to come through?
Aug 20, 2018 at 12:01 PM
DANIEL1986
Okay, I will check the pressure tomorrow and let you know and where exactly is the blend door at and how do you check it?
Aug 20, 2018 at 12:07 PM
  • 110,240 POSTS
Welcome back. I was not able to find an exact picture specific to your vehicle. However, here is a link that describes what it is, does, and in general how they are checked and replaced. The blend air door is located under the dash in the heater box.
Let me know if this helps.
Aug 21, 2018 at 11:10 AM
DANIEL1986
Is there any way to check and make sure the actuator is bad? Does it sound like a expansion valve could be bad too?
Aug 30, 2018 at 2:46 AM
