Hey HASSAN SHUAIBU,
Does the same thing happen when you turn electrical loads on?
Does the A/C work?
Turn on all electric items eg. headlights, rear window defogger, wipers.
If this load does not affect the idle then you may have an issue with the the A/C compressor.
How is the idle generally?
Stable and smooth?
A good place to start would be to clean the throttle body on your vehicle. Guide below:
Also check for vacuum leaks:
I do not have the specifics for your vehicle but i would also advise checking your idle control valve and cleaning if necessary.
You may be able to find a guide for this online.
If you post some pictures we should be able to identify the items you need to remove/clean.
Regards, Joe
Mar 29, 2019 at 10:39 AM
