A/C does not blow cold air, how do get the compressor to turn/run so it will take refringent?
2009 MAZDA 3
130,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
DOM
Hello, when I turn on the A/C button and the fan motor is set too high, the A/C light glows steadily, as before when the A/C worked. I am 100% sure the compressor is not turning. Clutch is not engaging or cycling. I believe the condenser far, electric, is turning. Is there some way I can get the compressor to turn/run so it will take refringent? I have not done any electrical testing yet. The heater works fine and vents all work as it should.
Jul 31, 2022 at 12:56 AM
  • 55,433 POSTS
So, the only reason the compressor will not turn on is the refrigerant is low, so if you connect a recharge kit or gauge set and open the low side valve or just add refrigerant the compressor will turn on so you can continue to fill the system. These videos will help you see what's going on and I have included a guide to go over as well:
https://youtu.be/4EqdrBVb0sY
and
https://youtu.be/uZrQCGwXfek
This guide can help:
Aug 1, 2022 at 2:05 AM
