AC water leaks inside the car
6 CYL • AUTOMATIC
ABDUSSLAM
Hi , please I really need your help as soon as possible, I have a water leak in my car under the feet of the driver , and it's a lot of water , I followed your steps trying to clean the drain hose but I found it was not clogged it's all ok , but from inside the car in the middle under the dash still leaking, now I think the problem is from the box which holds the water and then to release it to the drain hose short tube, I think but not sure this box is broken or something, my car is Tucson 2005 .. Please tell me what to do and how do I make sure of the leak place . Thank you
Oct 20, 2015 at 3:04 AM
CJ MEDEVAC
  • 11,000 POSTS
THIS STILL REALLY SOUNDS LIKE A CLOGGED DRAIN
SEE THE INFO IN MY LINK, MY METHOD MIGHT BE OF SOME HELP
https://www.2carpros.com/questions/2009-buick-la-crosse-clogged-drain
LET ME KNOW IF THIS HELPS ANY
THE MEDIC
Oct 20, 2015 at 1:12 PM
