Ac vacuum question?
1,000 MILES • AUTOMATIC
BHAMDOC1
  • 423 POSTS
What happens to any freon left in the system does it also get rid of it? Alao, wgere does the moisture go when its vacuumed? And if it also sucks out any freon left does it clean it to pretty much zero freon level? This is just a general question and does not really pertain to a specific car
Jul 8, 2026 at 8:55 AM
  • 55,711 POSTS
Sure, when the system has a leak the refrigerant leaks into the atmosphere, and when the AC system is opened moisture can get into it and must be vacuumed down to remove it. The moisture from the system leaves the vacuum pump which is seen at the pump. Please go over this video to see how the job is done start to finish.
https://www.youtube.com/watch?v=QuK9iAdXGKM
Let me know if you need anything else.
Jul 9, 2026 at 9:02 AM
