Car shuts off when I press A/C button
200,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
KRAGEANDSAM38
With the car running I push the A/C button and the car shuts off immediately.
Jul 30, 2020 at 3:17 AM
  • 110,248 POSTS
Does this only happen when at an idle? Does the A/C work when the vehicle is moving? Is there any noise associated with this when it happens?
I'm asking for a few reasons. If it's at idle only, the idle air control valve can be bad. If it happens at all times, the compressor could be locked up. However, I would think you would hear belt noise if that is the case.
Jul 30, 2020 at 6:12 AM
