A/C temperature display in Celsius and I wanted it in Fahrenheit?
105,000 MILES
TMICHAELB
The car was built in Canada. I’ve gone through all the settings. I can change the outside temperature display to Fahrenheit but not the A/C temperature.
Feb 10, 2024 at 6:39 AM
  • 110,248 POSTS
Wow, that is a good question. I'm not sure it can be done. If it can, however, you will likely need a Nissan scan tool that can reprogram the HVAC control module.
You indicate it was built in Canada. Was it originally sold in that market?
Feb 11, 2024 at 7:23 AM
TMICHAELB
I’m sure it was sold in Canada originally. I’m in Florida, so not sure how it got here the history of the vehicle other than that I’ve done some research on the Nissan forums and apparently changing the A/C temperature. Climate control head does not work. There apparently is another part deeper behind the dash that you need to change that’s the one I’m trying to find out about.
Feb 12, 2024 at 9:52 PM
  • 110,248 POSTS
I'm not sure what other component they would be referring to. Do you recall seeing anything about the AC amp?
Feb 13, 2024 at 6:54 AM
