A/C takes some time to start cooling after delay by the evaporator
165,000 MILES • 1.5L • 4 CYL • AUTOMATIC
PWPYCOOLA
  • 5 POSTS
Hello, when i turn on my car A/C, it starts cooling immediately but once the cooling is cut or delayed by the evaporator, it takes about 15 minutes to 20 minutes before it starts cooling again. Thanks
Jun 17, 2022 at 9:56 PM
I am not sure what you mean by it is cut by the evaporator. Do you know that there is something wrong with the evaporator that is causing this?
This sounds like you have moisture in the system, or the evaporator is freezing and it is cutting off the compressor so that it will thaw and then it starts again.
So, we need to start with finding out what the pressure is before the compressor is cut off.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
So, let's start with getting the pressure and then we will know what direction to go.
I attached a chart below that will help with determining the cause based on pressure.
Thanks
Jun 19, 2022 at 12:23 AM
