AC system/relay
225,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
FIXITMR
  • 9,989 POSTS
AC not working bought van that way it seems all there. i was gonna jumper relay to fill with freon. chiltons online says could be dual air? how do i tell? has dual heat. chiltons no help on finding relay my fender relays last 1 on right is GREEN has 4 wires main red and green small brown and green.
Mar 28, 2016 at 7:10 AM
FIXITMR
  • 9,989 POSTS
the relay rack is as follows its near pass fendero header. from fender relay 1 2 3 are gry 4 is blck 5 is green.
Mar 28, 2016 at 7:41 AM
HMAC300
  • 48,601 POSTS
hint if compressor won't start it may be out of Freon, if that is case then there is a leak and should be fixed...... see pic ac compressor relay behind right headlight
Mar 28, 2016 at 8:14 AM
FIXITMR
  • 9,989 POSTS
it may have a slow leak which is seasonal that is quite common. if not recharged eventually to low for compressor to start. your pic is nonspecific as to which relay is compressor
Mar 28, 2016 at 8:28 AM
HMAC300
  • 48,601 POSTS
funny I said behind right headlight....plus gave you a pic
Mar 28, 2016 at 9:28 AM
  • 55,865 POSTS
It looks like it #5 in the description. Can you double check the year, Mitchell1 does not show a transport for this year.
Apr 4, 2016 at 7:14 AM
FIXITMR
  • 9,989 POSTS
pretty sure transport went to 96 i know its a 95 it an odd/special yr for the diagnosis system OB
Apr 7, 2016 at 8:03 AM
FIXITMR
  • 9,989 POSTS
my latest news is its #2 from fender but still dont have wiring diagram and all the wires on #2 are the same size.
Apr 7, 2016 at 8:05 AM
HMAC300
  • 48,601 POSTS
unplug relay if you are going to jump it there. also pic of pressure switch.
Apr 7, 2016 at 9:23 AM
FIXITMR
  • 9,989 POSTS
been so cold here i've had no interest in working on it may be a week or longer
Apr 7, 2016 at 10:05 AM
  • 55,865 POSTS
Please let us know what you find when it warms up
Apr 10, 2016 at 6:47 AM
FIXITMR
  • 9,989 POSTS
o which wires am i jumping? pink to green?
Apr 13, 2016 at 3:17 AM
  • 55,865 POSTS
You will jump the pink to the green
Apr 13, 2016 at 4:25 AM
FIXITMR
  • 9,989 POSTS
yup that makes the compressor run gonna try to test for leaks before attempting to charge its completely empty as far as i can tell.
Apr 13, 2016 at 10:28 AM
  • 55,865 POSTS
Okay let us know how it goes
Apr 13, 2016 at 11:28 AM
FIXITMR
  • 9,989 POSTS
so i added freon and it lasted the summer! now its hot again this yr and AC not working again! so i'm here to see what i did last time!
Jun 2, 2017 at 7:52 AM
FIXITMR
  • 9,989 POSTS
same deal jumpered relay plug added freon working again
Jun 3, 2017 at 12:21 PM
