A/C gets colder as i drive but at idle it stops blowing cold like it should
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOYPACIFIC
  • 159 POSTS
I know i was here recently about finding the evaporator and expansion valve, but i have this question that might help me understand whats going on. so i changed out the condenser and A/C compressor both new .
i filled up the Freon with one of those gauges i bought from Napa. i got it filled up but not to high just to where my gauge reads full. anyways A/C compressor goes on, cooling fan is spinning and A/C is cold. although it's not as cold as it should be and it does get cold like it should when driving, but as i'm idling it will get a little warmer. now just to be clear this was the reason why i changed out those components with newer ones. A/C had just the right amount of oil. so i'm stuck here thinking maybe i still need to change out the expansion valve and evap.. any suggestions as to why this problem might still be happening?
Sep 18, 2020 at 7:40 PM
Good morning,
What is the pressure at idle with the A/C on?
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
You cannot tell Freon level by gauge readings at all.
You really should have a set of gauges so you can read the high and low side pressures.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
The correct way of filling the system is to evacuate the system for about an hour and then fill with the exact amount of Freon .
I need to see both readings so I can determine if you need the expansion valve.
Sep 18, 2020 at 9:18 PM
TOYPACIFIC
  • 159 POSTS
okay, good idea. I will probably take it into a shop have them evacuate and refill to recommended levels.
Sep 18, 2020 at 9:59 PM
Keep us updated.
Sep 18, 2020 at 10:05 PM
