I know i was here recently about finding the evaporator and expansion valve, but i have this question that might help me understand whats going on. so i changed out the condenser and A/C compressor both new .
i filled up the Freon with one of those gauges i bought from Napa. i got it filled up but not to high just to where my gauge reads full. anyways A/C compressor goes on, cooling fan is spinning and A/C is cold. although it's not as cold as it should be and it does get cold like it should when driving, but as i'm idling it will get a little warmer. now just to be clear this was the reason why i changed out those components with newer ones. A/C had just the right amount of oil. so i'm stuck here thinking maybe i still need to change out the expansion valve and evap.. any suggestions as to why this problem might still be happening?
Sep 18, 2020 at 7:40 PM
