A/C not blowing cold air
114,000 MILES • 4.0L • 6 CYL • 2WD • MANUAL
JORGEQSXO
My car listed above blows air and all the levels work but doesn’t blow any cold air at all. What could be causing this problem? A/C condenser?
Jul 16, 2020 at 11:09 AM
  • 110,251 POSTS
The most common cause of the A/C not to work is due to low refrigerant in the system. Have you tried to recharge the system? Take a look through this link. It explains the most common causes of an A/C system not working or working poorly. It walks you though what to check and how to do it.
If you have already checked the refrigerant levels, let me know.
Jul 16, 2020 at 11:20 AM
