My car listed above blows air and all the levels work but doesn’t blow any cold air at all. What could be causing this problem? A/C condenser?
Jul 16, 2020 at 11:09 AM
✓Experienced Mechanic
The most common cause of the A/C not to work is due to low refrigerant in the system. Have you tried to recharge the system? Take a look through this link. It explains the most common causes of an A/C system not working or working poorly. It walks you though what to check and how to do it.
