AC started blowing hot air...clutch is not engaging
75,000 MILES
RENTALARAJ
From past few weeks AC started acting wierd. It used to run find in mornings but as the day got hotter or if I put vehicle in sun the AC used to switch cool air to hot air once in a while.
From yesterday it is only blowing hot air. I showed it to a mechanic and he says there is a voltage but thinks the clutch coil is the problem. Asking around $600 to change it.
Just want to be sure it is not a simple relay problem or Freon pressure. Repairshop couldnt find out the pressure as clutch is not engaging. Can I short it and measure the pressure? if so how could I do it? Also how to check whether it is a relay problem (I was reading lot of online forums and MDX has relay problems for this year range)
Sep 7, 2014 at 1:35 AM
  • 110,246 POSTS
He can check static pressure to see what the system has. That is checked when the system is off. Also, is the compressor engaging when you turn it on? In other words, do you hear it click on and off?
Sep 7, 2014 at 10:16 PM
  • 110,246 POSTS
Sorry, I just saw you mentioned it wasn't engaging. He first needs to check static pressure to see if the system is low on Freon. If it isn't. then the issue deals with a power supply to the compressor clutch. Most likely a cycle switch.
Sep 7, 2014 at 10:17 PM
