A/C suddenly stopped working?
140,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
SPLIT082004
I found a burned hole through the wire that connects under the engine cover. The wire runs from the compressor to the engine harness I'm assuming. The hole is on the engine side of the connector. Can you tell me what this part is called? I'm looking at and seeing an A/C compressor pigtail. I hope this is the part. Could you also tell me how to connect the loose wires if this is the right part. Thank you so much.
Aug 27, 2022 at 3:38 PM
  • 55,816 POSTS
Can you upload a picture or a short video please? Here are the wiring diagrams for the compressor to see if the color wiring is the same. They don't show pictures of the engine wiring harness, just diagrams.
Aug 28, 2022 at 10:43 AM
