A/C relay removal
120 MILES • 3.5L • 6 CYL • 2WD • MANUAL
ALEX KUMARA
How do I remove the air conditioner relay? Seems to be stuck. Thanks in advance.
Aug 26, 2017 at 11:15 AM
  • 55,554 POSTS
Can you please confirm the car model and year?
Cheers, Ken
Aug 28, 2017 at 9:58 AM
STEVE W.
  • 15,370 POSTS
Also which relay, the HVAC blower motor or the AC compressor clutch relay?
The blower motor relay is in the fuse panel/junction block and should just pull out.
The AC clutch relay however is built into the IPDM (intelligent power distribution module) and is not a serviceable part, you replace the entire module to replace the relay and it has to be programmed with the VIN number to match your car.
That is the same for Infinity 2008 G35 & M35 And 2009 G37 & M35 models.
Aug 29, 2017 at 2:58 AM
PAULMARIE
  • 0 POST
IPDM does not need to be reprogrammed if a new one is replaced.
Sep 21, 2018 at 8:00 AM
