Ac radio windows turn signals speedometer not working?
205,000 MILES
MADAMEAMALVEAUX
  • 8 POSTS
Having same issues as https://www.2carpros.com/questions/2004-toyota-4runner-center-console-radio-ac-fan-controls-dead-well-automatic-w I've checked ecub fuse it's not getting power battery is good alternator good I think possible can issue . I need to know what connects all of these to can network I heard it was something in passenger door us that correct?
Jun 18, 2025 at 9:28 AM
STEVE W.
  • 15,389 POSTS
It appears the original poster never returned with the repair. You state that the ECU-B fuse isn't getting power? Is that using a test light to see if the circuit isn't getting power? If I can ask, does the engine run? Does the horn work? How about the headlights? Interior lights?
Asking to see if it narrows down to a single circuit or branch. ECU-B is fed through the junction box in the engine compartment. Basically it goes from the battery to the fuse link assembly and into the junction box where it goes on a solid bus in the box, through a shorting pin and to the fuses. The DRLs, and horn are on the same circuit. If they work then power is getting to the box. Then the next test would be to see if there is power going through the shorting pin. If there is power to the shorting pin, but no power at ECU-b then the issue is likely internal to the junction box. BUT there is a way to test beyond that. You would make a jumper lead out of a fuse tap type wire. connect it to battery positive and put a 10 amp fuse into it and plug it in in place of the 10 amp ECU-b fuse and see if those items come back on. If they do then the issue is internal to the junction box and a replacement box would likely repair it.
Jun 18, 2025 at 5:52 PM
MADAMEAMALVEAUX
  • 8 POSTS
Did u find out what was the problem with yours I'm having same issue
Jun 19, 2025 at 4:15 AM (Merged)
STEVE W.
  • 15,389 POSTS
Have you had any luck testing the fuses?
Jun 20, 2025 at 8:43 AM
MADAMEAMALVEAUX
  • 8 POSTS
i couldnt find this site again until now im so happy i found u again .i listed my newest issues which may be connected with the prior electrical issues but my radio speedometer work now and my ecu. fuse is working after changing some fuses and relays but now no ac still except rear hot cant get windows on sliding doors up or down and all of the other issues i just listed above.. with door anar battery dying etc
May 10, 2026 at 7:47 AM
MADAMEAMALVEAUX
  • 8 POSTS
i have twst light and multimeter but i dont know what to check forst or in what order and ive been around in circles so much i dont remember what all ive checked and not checked so i need a step by step start to finish on whats related whats not related and what to do because i don't know if this is all from one issue or multiple separate issues
May 10, 2026 at 7:50 AM
MADAMEAMALVEAUX
  • 8 POSTS
and i live in las vegas and pretty soon it will be too hot to check or to drive if i cant figure it out so please help me
May 10, 2026 at 7:51 AM
  • 55,616 POSTS
Please do, Steve W. is one of the sites best techs.
May 12, 2026 at 8:45 AM
