AC pump stays on, no cold air
148,095 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
JENNIFER HUNNELL-MULLINS
We just replaced the AC pump and had it charged. The air is not getting cold. The pump stays on it does not shut off and the air does not blow cold.
May 12, 2018 at 6:12 AM
Good evening.
Do you have the high and low side gauge readings?
It may be a blend door actuator not changing to cold air. I attached a article on the subject.
Procedure:
1. Remove the IP compartment.
2. Disconnect the air temperature actuator electrical connector.
ImageZoom/Print
3. Remove the two screws from the actuator.
4. Remove the air temperature actuator.
May 12, 2018 at 8:05 AM
