Air conditioner problim
233,000 MILES • 4.3L • V6 • 4WD • MANUAL
AHMED KAMAL
When I start the engine I noticed the climate control system seems to be loosing the effect on the air blend passage doors with noisy opening/closing, it starts blowing very cold air then followed with very hot air and so on, but after long driving it comes back to normal. It happens again if I switch off and restart the engine.
Mar 4, 2016 at 1:51 PM
WRENCHTECH
  • 20,760 POSTS
Is it an automatic temperature control system or manual?
Mar 4, 2016 at 10:25 PM
AHMED KAMAL
Yes it is an automatic temperature (climate control system).
Mar 7, 2016 at 3:11 AM
WRENCHTECH
  • 20,760 POSTS
Check fuse #19 labeled RDO battery. It sounds like the module is not retaining memory. It goes through a self test whenever the power is disconnected, but it's not supposed to do it by merely shutting the key off. I'm thinking it may not have any keep alive memory power.
Mar 7, 2016 at 3:19 AM
  • 55,710 POSTS
It sounds like the blend door actuator is going bad, here is more information on it
and video
https://www.youtube.com/watch?v=Eqf-H3COtSo
please let me know how it goes
Mar 11, 2016 at 12:20 PM
