Air conditioner problems
144,000 MILES • 6 CYL • 2WD • AUTOMATIC
WOODWARD2213
  • 5 POSTS
If I am in my drive way and turn on my air conditioner my car dies. If I am driving it works, but my car overheats. If I come to an idle if my car does not die the rpm's will pulse. If the air conditioner is off I have none of these issues. Any ideas?
Jun 10, 2016 at 11:12 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like a bad air conditioner compressor, with the engine off and cold see if the center of the air conditioner compressor pulley turns freely.
Jun 10, 2016 at 3:05 PM
WOODWARD2213
  • 5 POSTS
Should the belt be on or off? Tried it with the belt on and its solid as a rock.
Jun 11, 2016 at 2:39 AM
WOODWARD2213
  • 5 POSTS
Ok should the belt be on or off? Tried it with the belt on and its solid as a rock.
Jun 11, 2016 at 3:53 AM
CJ MEDEVAC
  • 11,000 POSTS
Different feller
Maybe my pic will help? See Below
The Medic
Jun 11, 2016 at 9:16 AM
SATURNTECH9
  • 30,869 POSTS
With the belt on and engine off the center should spin.
Jun 11, 2016 at 1:17 PM
WOODWARD2213
  • 5 POSTS
Oh yea it spins free.
Jun 11, 2016 at 11:30 PM
  • 31,937 POSTS
The comp may be seizing up, the clutch is free running but the comp when the clutch energizes is causing the problem.
Jun 12, 2016 at 9:50 AM
SATURNTECH9
  • 30,869 POSTS
The center of the AC clutch is attached to the AC compressors shaft when the AC clutch engages it connects the out side pulley which is spun by the drive belt.unless it has a valve style compressor which the center of the pulley spins all the time.Until the valve activates the compressor.
Jun 12, 2016 at 10:20 AM
SATURNTECH9
  • 30,869 POSTS
I have seen AC clutches go bad and kill the engine when they engage.But the SC compressor is fine.Can you take s picture of the AC clutch and post it.
Jun 12, 2016 at 10:22 AM
WOODWARD2213
  • 5 POSTS
The center spins free.
Jun 18, 2016 at 3:18 AM
SATURNTECH9
  • 30,869 POSTS
Is your radiator fan working properly?
Jun 19, 2016 at 4:00 AM
SATURNTECH9
  • 30,869 POSTS
I didn't catch when you first asked the question you said something about it overheating.
Jun 19, 2016 at 10:38 AM
