A/C fan only works in cooler temperatures?
100,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
MUGSYREYES
The A/C compressor is engaged but the fan motor is not running. fan motor does work in mornings but not in the afternoons.
Jun 28, 2023 at 2:44 PM
  • 55,647 POSTS
This is a common problem when the blower motor starts to go out or you have a bad connection at the blower motor or control module. Here are the locations and a guide on how to test the blower motor power and ground to help confirm the failure. Here is a generic guide to help you step by step with instructions in the diagrams below to show you how to use your car.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jun 29, 2023 at 5:26 AM
