A/C compressor is humming real loud at idle and give it gas it stops
20,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
CHRISTOPHER MORRIS
Yes, I put brand new it compressor, accumulator, orifice tube, replaced, o-rings put new A/C hose on.
Aug 18, 2020 at 5:27 PM
Good morning,
Can you upload a video of the noise so I can hear what you hear?
Do you have gauges to give me the high and low side readings at idle?
How much oil did you add to the compressor before installing it to the truck?
Aug 18, 2020 at 8:36 PM
FREEMBA
  • 1,152 POSTS
Often a humming/buzzing noise can be caused by overfilling the A/C system (too much refrigerant in the system). A refrigerant recovery system (machine) has to be used to evacuate the A/C system (without polluting the atmosphere) in order to remove some of the refrigerant and them restore the A/C system to its proper oil and refrigerant levels.
If I read your post correctly, you replaced the compressor. Is that correct?
If not, compressor humming noise could signify internal compressor problems which would require a new compressor.
Aug 19, 2020 at 2:55 AM
CHRISTOPHER MORRIS
I figured it out it was a vibrating issue. thanks
Aug 19, 2020 at 8:22 PM
Good job.
Glad it is fixed.
Aug 19, 2020 at 8:27 PM
