AC problem
194,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
TUMADREHP
my AC comes on, it cools well when car in on the highway . so then I checked and the condenser coil fan does not work. the fan that is behind the engines radiator and the AC coil (condenser) . I connected straight from battery and the fan works. can some one send me the AC wiring diagram to trace the wires back to the AC relay thank you so much in advance.
May 26, 2019 at 2:38 AM
KENW1
  • 213 POSTS
Thanks for visiting 2CarPros.
I'll post the diagram below. This is a two speed fan so there is a high and low speed relay. The fan should kick in when the high pressure side is at around 300-350 psi. if the wiring and relays check out it's most likely an issue with the pressure switch.
May 26, 2019 at 3:56 AM
TUMADREHP
Guys thank you so much for your time, for your help . amazing you guys and this web site exist. Thank you one more time .
May 27, 2019 at 4:01 AM
  • 55,694 POSTS
KENW1 is one of our best! Please let us know what you find. We are interested to see what it is.
May 29, 2019 at 1:27 PM
