My A/C not working
2,000,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
JPRIETZ
  • 11 POSTS
Hello, I'm trying to help my elderly friends truck A/C problem. It works real good blowing cold air, then after a while it starts to blow warm air. This happen at random times. I put the gauges on and at 92 outside time, A/C clutch is engaged, low side is 100 psi and the high side is at 242 psi., engine is at ideal, A/C set at max and fan speed on high. Any thoughts?
Aug 18, 2019 at 5:02 AM
This sounds like the compressor has gone out or the system is low on charge or a fuse is bad, these videos and guides can help us fix the problem with diagrams below to show you how on your car. I have included (below) the air conditioner wiring diagrams as well so you can see how the system works.
https://youtu.be/4UjfQKvrB6Y not working
and
https://youtu.be/uZrQCGwXfek recharge
and
https://youtu.be/yrhWKlQEPWw leak detection
and
https://youtu.be/4EqdrBVb0sY vacuum and recharge
and
Let us know what happens and please upload pictures or videos of the problem.
Apr 15, 2021 at 7:42 AM
JPRIETZ
  • 11 POSTS
Thanks Roy for your reply and information. Will give this a try and let you know after the system is vacuum out and recharged. Question, since I'm only changing out the orifice tube and the filter dryer should I only add 2oz of oil to the filter dryer?
Jeff
Yes, do add that. Add it to the dryer before installing.
