AC pressure switch location
73,250 MILES • AUTOMATIC
CATAFINA
  • 98 POSTS
Low and high pressure switch location and AC electrical diagram.
Aug 31, 2018 at 2:30 PM
Good evening.
I attached a wire diagram and a hose diagram that shows the location of the high and low side fittings.
Sep 1, 2018 at 10:46 AM
CATAFINA
  • 98 POSTS
Sep 6, 2018 at 10:29 AM
You are welcome. Always glad to help.
Sep 6, 2018 at 10:45 AM
CATAFINA
  • 98 POSTS
Can you tell me what does it mean if you have a key and in the middle an exclamation point?
Sep 30, 2018 at 9:18 AM
CATAFINA
  • 98 POSTS
CATAFINA
  • 98 POSTS
2008 Mitsubishi Outlander.
Sep 30, 2018 at 9:19 AM
Could be a theft or security issue.
Does it start and run.
Can you post a picture?
Sep 30, 2018 at 9:20 AM
CATAFINA
  • 98 POSTS
It will not do anything when you engage/start the vehicle not running. I am thinking it is the key fob not matching up with immobilizer. Perhaps the battery in the fob, doubt it has ever change in ten years time. When through the reset procedures hear nothing. Should I go and have the battery change and get the key reprogrammed for a start? Thank you very much. Willing to take your advice on anything that might help. Note: One key is will not even blink.
Sep 30, 2018 at 11:14 AM
CATAFINA
  • 98 POSTS
Does the vehicle has to be present in order to reprogram the key by the dealer?
Sep 30, 2018 at 11:16 AM
Yes it does. A locksmith can come to you to program the key.
Do you have another key to try?
Sep 30, 2018 at 11:20 AM
CATAFINA
  • 98 POSTS
Sometimes I get lucky starting it without doing anything.
Sep 30, 2018 at 11:21 AM
Did you try replacing the battery in the key fob?
Sep 30, 2018 at 11:39 AM
CATAFINA
  • 98 POSTS
No not yet.
Sep 30, 2018 at 11:40 AM
CATAFINA
  • 98 POSTS
The other key probably needs battery does not even blink or what does it two keys have to work for it to start or just one.
Is Mike still there?
Sep 30, 2018 at 11:46 AM
Name does not ring a bell. I will check with Ken.
Sep 30, 2018 at 11:57 AM
CATAFINA
  • 98 POSTS
Anything else you can add to the problem before I take in to the dealer?
Sep 30, 2018 at 6:45 PM
I checked with Ken and he is no longer answering on line, sorry.
Hard for us to diagnose over the posts we have since we cannot see it, touch it or physically check it ourselves.
Did you check the battery for correct voltage? It should be 12.6 volts with the engine off.
Sep 30, 2018 at 9:30 PM
