Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Firebird
Climate Control
Air Conditioner
Pressure Sensor
ac pressure sensor
2002 PONTIAC FIREBIRD
87,000 MILES • 3.8L • V6 • RWD • AUTOMATIC
BILLMILL5050
MEMBER
How would I ckeck if ac pressure sensor is good I'm getting code p1639 thanks
Aug 30, 2016 at 5:34 AM
WRENCHTECH
Experienced Mechanic
Examine the data with a scan tool and you can see what pressure the sensor is signaling to the computer.
Aug 30, 2016 at 8:03 AM
BILLMILL5050
MEMBER
P1639 IS MANUFACTURERS COMPUTER AND AUXILIARY OUT
Aug 30, 2016 at 3:51 PM
It is a three way pressure switch, use this wiring diagram to help you.
Image (Click to enlarge)
Sep 1, 2016 at 6:21 AM
BILLMILL5050
MEMBER
is this it? will the ac leak if I take off ? does it un-screw? thanks all i appreciate it
Sep 1, 2016 at 6:53 AM
WRENCHTECH
It may have a schraeder valve under it to hold the refrigerant but I wouldn't take the chance that it may not. I would evacuate the system first.
Sep 1, 2016 at 8:00 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
