A/C pressure even on low and high sides?
2001 FORD MUSTANG
154,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
SHAWN MACQUEEN
  • 6 POSTS
I bought my car with a locked-up A/C compressor. I changed out the compressor, flushed out 6 ounces of oil from the evaporator, replaced the condenser, drier, flushed all lines. A/C will not accept freon, won't pull it in. System is 110 psi on low and high side with compressor running by jumping the low-pressure switch with jumper wire.
Jul 22, 2023 at 5:28 AM
MATHGEN
  • 128 POSTS
Did you replace the orifice tube?
Jul 22, 2023 at 9:05 PM
SHAWN MACQUEEN
  • 6 POSTS
Yes, I replaced orifice tube, condenser, drier, flushed evaporator and li es also. Maybe they sent me a bad compressor from the get go?? A/C clutch does spin however.
Jul 24, 2023 at 11:22 PM
MATHGEN
  • 128 POSTS
Are the valves on the manifold gauge set fully open?
Jul 25, 2023 at 2:00 AM
SHAWN MACQUEEN
  • 6 POSTS
Yes, they are both open fully.
Jul 26, 2023 at 10:13 AM
SHAWN MACQUEEN
  • 6 POSTS
Basically, I've replaced or flushed everything I could. The evaporator has been flushed twice just to make sure it's free flowing. A/C compressor clutch spins when you jumper the low-pressure switch. Flushed lines etc. There can't or shouldn't be any obstructions?!? I can only go back to wondering if it's the remanufactured ac compressor bad from get go maybe?
Jul 26, 2023 at 10:18 AM
SHAWN MACQUEEN
  • 6 POSTS
In the site glass you can see the Freon just sitting in the gauges there not being sucked into the low side at all.
Jul 26, 2023 at 10:19 AM
MATHGEN
  • 128 POSTS
At this point I would agree that you may have a faulty compressor.
Jul 27, 2023 at 1:01 AM
SHAWN MACQUEEN
  • 6 POSTS
I'm going to swap out the ac compressor again and I'll let you know what the results are. Thanks for your insight! Fingers crossed.
Jul 27, 2023 at 10:18 PM
  • 110,244 POSTS
I notice we haven't heard from you for a couple of days. Have you had any luck replacing the compressor? We're interested in knowing.
Jul 30, 2023 at 1:57 PM
