Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Avalon
Climate Control
Air Conditioner
Switch
AC only stays on if button on dash is held down.
1998 TOYOTA AVALON
150,000 MILES • V6 • AUTOMATIC
CIGAN
MEMBER
1 POST
If I hold the AC button down on the dash, AC works as normal. Let go and the compressor disengages. Is it the button or a relay?
Sep 12, 2015 at 9:50 AM
WRENCHTECH
Experienced Mechanic
Yes, it sounds like the button switch is bad.
Sep 13, 2015 at 12:11 AM
CIGAN
MEMBER
1 POST
Thanks, Now I just need to figure out how to get to it without removing the whole dash.....
Sep 13, 2015 at 3:39 AM
WRENCHTECH
That is going to be built into the Control head assembly. You nhave to remove the outer bezel first and then the assembly is screwed in.
Sep 13, 2015 at 3:44 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
