AC only blows through defrost vents
140,000 MILES • 2WD • AUTOMATIC
CDRUCK
Originally the AC compressor would not come on at all so I added some Freon from a can and it came on to the point where it started cycling on and off. Air only blows through the defrost vents and I know that could have something to do with a vacuum leak. But could it have something to do with the cycling? Should I add more Freon?
May 16, 2019 at 3:39 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your Defrost Actuator. If your actuator, through normal wear and tear, breaks, it will stay in the position it breaks in. I have included in the diagrams down below a link for you to go to.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Please go through the guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
May 16, 2019 at 5:51 AM
JIS001
  • 3,412 POSTS
Hello and thank you for using 2CarPros. I would agree with you CDRUCK that the problem is a broken vacuum line. Very common fault with Ford. You would need to trace the vacuum lines in the engine bay for a broken plastic vacuum line. The climate control unit also has a vacuum plug in the back to control the the air distribution. Worse case scenario the climate control head is defective but I am pretty sure if you look at all the plastic vacuum lines near the engine firewall you will find a broken vacuum line. Let us know what you find.
May 16, 2019 at 5:21 PM
