ac not working and car sputtering
95,550 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
GOTMILK789
First my ac or heat haven't worked since I bought the vehicle. Basically when you turn on the heat or ac, neither do what they are supposed too. The heat blows air but not hot and ac blows air but not cold. Now with my transmission it seems as if it is sputtering. I press on the gas and there really is not any power. It almost seems to be sputtering or missing the gear. Thanks for the help
Jun 7, 2014 at 10:02 AM
  • 110,248 POSTS
As far as the heat and AC, check to make sure the blend air door is working. Check that the compressor is engaging. With the engine hot and running, turn the heater on and check to see if the heater core hoses get hot.
Let me know what you find,.
Jun 7, 2014 at 12:56 PM
