AC not working
130,000 MILES • 1.4L • 6 CYL • 2WD • MANUAL
ABUBAKARS.MATORI
I have 307, and when the battery went flat the car locked it self and I had to use BIS code to reset the system.
after resetting I discovered that the AC not cooling.
kindly advice if the problem is from the compressor.
Feb 25, 2018 at 7:57 PM
  • 31,937 POSTS
You first need to get the A/C high and low system pressures tested. we first need to determine if there is sufficient refrigerant in the system. post back the readings for further evaluation.
Feb 26, 2018 at 6:28 PM
