AC not working
68,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BLAZERMAN67
When the car is at idle the system works, but as soon as you accelerate it blows warm air. I have remove the belt and inspected it and the compressor clutch and pulley. No issues detected. I put my gauges on it and my charge pressures are 50 psi low side and 180 high side this was at idle, once I accelerate the pressures change to approximately 100 psi low side and 40 psi on the high side. Then it blows warm air. I was thinking expansion valve but I am not sure. Please help.
The clutch was engaged the when accelerate.
Jun 25, 2017 at 12:12 AM
HMAC300
  • 48,601 POSTS
are you sure the gauges are hooked up right? if it is it sounds like a blockage at compressor. recheck your gauge hook up.
Jun 25, 2017 at 3:26 AM
BLAZERMAN67
I rechecked the pressure, this time static was 120 on both and 120-125 with the compressor engaged . I'm thinking compressor is no longer pumping
Jun 27, 2017 at 1:03 PM
HMAC300
  • 48,601 POSTS
if pressures stay the same as static it's a compressor problem bu if compressor went out it sends pieces all throught eh system so it h as to be flushed out and cleaned along with orfice/screen change if it has one as well as receiver drier before even putting new compressor on. of course if compressor is not engaging then the pressure will stay the same.
Jun 27, 2017 at 11:30 PM
