A/C it won't blow any air at all?
231,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
CHRIS KINARD
  • 97 POSTS
My A/C was working fin then all the sudden it doesn't turn on anymore, it won't blow any air at all.
Dec 8, 2024 at 3:16 AM
  • 55,817 POSTS
Hey Chris,
Can I ask if the air not blowing is the problem or the air is blowing but not cold? Please let me know so we can head in the right direction to fix it. :)
Dec 9, 2024 at 12:53 AM
CHRIS KINARD
  • 97 POSTS
It's not blowing any air.
Dec 9, 2024 at 12:54 AM
  • 55,817 POSTS
Okay, most of the time it will be the lower motor but as should check the fuse #24 which is under the fuse panel.
Here is a guide that can help and the fuse location in the diagrams below:
Check out the images (below). Let us know how it goes.
Dec 10, 2024 at 1:57 AM
CHRIS KINARD
  • 97 POSTS
The fuse is good.
Dec 10, 2024 at 3:13 AM
  • 55,817 POSTS
Okay good, let's use this guide to check for power and ground at the blower motor, chances are the blower motor has gone bad but this will confirm the problem.
https://www.2carpros.com/articles/how-to-test-an-automotive-hvac-system-blower-fan-motor-a-detailed
Dec 11, 2024 at 1:59 AM
CHRIS KINARD
  • 97 POSTS
I also remember smelling something like burning.
Dec 13, 2024 at 1:51 AM
  • 55,817 POSTS
Yep, this was most likely the blower motor burning up, does the fan motor not wok at all speeds?
Dec 13, 2024 at 4:50 AM
CHRIS KINARD
  • 97 POSTS
Yes, it doesn't work at all.
Dec 13, 2024 at 5:20 AM
  • 55,817 POSTS
Up, chances re the blower motor is bad, I would use the guide above to confirm the issue and then replace the blower motor.
Dec 14, 2024 at 2:09 AM
