Does this mean the clutch is bad?
154,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JACKBURKHART
  • 5 POSTS
R-134 F guava says it’s okay. I looked at clutch and it was not moving when AC is on. I tapped it and started turning and started to cool. Does this mean the clutch is bad?
Jun 28, 2019 at 12:14 PM
BMDOUBLE
  • 1,139 POSTS
This is not the recommended diagnostic procedure, but in the real world that is one way to verify that yes the clutch is bad! You are spot on sir!
Jun 28, 2019 at 12:40 PM
JACKBURKHART
  • 5 POSTS
Thank you BmDouble.
Is it possible the change the clutch without removing the compressor?
It is a very tight area and I am not sure if I can even get to it. Any suggestions?
Jun 28, 2019 at 1:00 PM
BMDOUBLE
  • 1,139 POSTS
From what I remember on the 2006 F-150's, you should be able to get to it from underneath. Just lay on a creeper and you can see it from behind the bottom of the shroud. It’s tight but it can be done my friend!
Jun 28, 2019 at 1:24 PM
JACKBURKHART
  • 5 POSTS
Okay thanks. Is the a special tool I need to take it off and would you know if it is readily available? I have seen some on amazon and are there shims I must keep and maintain a gap? I have been watching some YouTube.
Jun 28, 2019 at 3:01 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just to add my two cents. I've attached air gap specification below as a picture. A/C clutch removal/install tools are available at any local auto parts store in their tool loaner program for rent.Hope this helps and thanks again for using 2CarPros.
Danny
Jun 30, 2019 at 1:24 PM
JACKBURKHART
  • 5 POSTS
I have called several auto parts places the average price for A/C clutch is $100.00. I found them on Amazon for $35.00.
Just have to wait on shipping. They are Motor Craft parts also
Any suggestion's?
Jul 2, 2019 at 1:53 AM
  • 55,721 POSTS
Yes use the Motor Craft unit. Please let us know what you find.
Jul 4, 2019 at 9:10 AM
