Here is a full description in the system operation and your plug terminal connection information:
Tom
A/C CLUTCH
The A/C compressor clutch components provide the means to engage and disengage the A/C compressor from the engine accessory drive belt. When the electromagnetic A/C clutch field coil is energized, it magnetically draws the clutch plate into contact with the clutch pulley and drives the compressor shaft. When the coil is not energized, the pulley freewheels on the clutch hub bearing, which is part of the pulley assembly.
A/C compressor clutch engagement is controlled by the Powertrain Control Module (PCM) or the Engine Control Module (ECM), depending on engine application. When the A/C-heater control is set to any A/C position, it sends a request signal on the CAN-IHS bus to the Totally Integrated Power Module (TIPM), which then transfers the request on the CAN-C Bus to the PCM/ECM, which determines if operating conditions are correct for A/C clutch engagement. When all operating conditions have been met, the PCM/ECM sends a signal on a dedicated hard-wired circuit back to the TIPM to energize the internal A/C clutch high side driver. When energized, the A/C clutch high side driver provides battery current to the A/C clutch coil.
The A/C clutch control system is diagnosed using a scan tool See: A L L Diagnostic Trouble Codes ( DTC ) > Testing and Inspection.
The A/C compressor clutch components cannot be repaired and must be replaced if inoperative or damaged.
Images (Click to enlarge)
Sep 11, 2020 at 8:43 AM
(Merged)
