A/C not working?
140,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JACOBPAULSEN
  • 64 POSTS
So, I took my car to PepBoys to test the system.
They said it was the compressor, so I replaced it, vacuumed the system and recharged it and it still doesn't work it just blows hot air.
Aug 4, 2022 at 8:59 AM
  • 110,248 POSTS
When you turn the A/C on, do you hear the compressor engage? If you do, it could be an issue with the blend air door in the vehicle.
If it doesn't turn on, have you checked fuses and relays related to the compressor?
Let me know if the compressor comes on or not so I can better direct you.
Additionally, take a look through this link. You may find it helpful.
Aug 4, 2022 at 2:41 PM
JACOBPAULSEN
  • 64 POSTS
it does turn on we hear it engage.
Aug 6, 2022 at 5:02 AM
  • 110,248 POSTS
If you hear it engage, I suspect the problem is in the vehicle. Under the dash, driver's side. near the center, you will see the HVAC box. There are cables that go to it from the control panel.
One of the cables is responsible for the air temperature that enters the vehicle. I have a feeling the cable is broken, out of adjustment, or disconnected.
I attached a pic below so you can see the item to look for. It's not a great pic, but you should be able to find it. Check the cable I highlighted. Change the requested temperature between hot and cold to make sure it moved the air mix damper lever. If it doesn't or if it is hardly moving, check for a possible reason.
See pic below.
Aug 6, 2022 at 6:58 AM
JACOBPAULSEN
  • 64 POSTS
The air damper cable works just fine. any other ideas?
Aug 19, 2022 at 1:59 AM
  • 110,248 POSTS
Was it only the compressor that was replaced? If there are other components, let me know what they are.
Also, I need to know both the low-pressure and high-pressure readings when the system is on.
Question: When the cable moves the damper, do you hear a door opening and closing?
Aug 19, 2022 at 3:28 PM
JACOBPAULSEN
  • 64 POSTS
we got it to work it was the expansion valve thanks for your help though.
Aug 21, 2022 at 4:26 AM
  • 110,248 POSTS
Thank you for the update. I'm glad to know it's fixed.
Please feel free to come back anytime in the future. You are always welcome here.
Aug 21, 2022 at 10:37 AM
