A/C not getting cold and van runs hot when in park/idle
180,000 MILES • AUTOMATIC
AWILS
A/C was recharged it was completely out then when I got another can the can from previous day was already leaked out. Not to mention I got about 20 minutes of cooler air before it went back warm. It blows fine and I can tell when it goes from low (1) to high (5) it's a difference in how it blows as it should be just not cold. I also checked the filters in dash and OMG it was like a birds nest in both yarn leaves trash everything I had to vacuum them. Don't even know if I put them back in correctly just lays inside den. Also my car runs hot when it is sitting still. Maybe a fan isn't working and that's also why my A/C not working? My shade tree mechanic said needs new A/C compressor that's over $200.00 fix. the vehicle is very old, but I have a baby and it's hot in the south. Please help I don't even know what fuses/relays to start with.
May 23, 2020 at 4:30 AM
So this is going to most likely be two different issues. Let's tackle the A/C issue here and the we will need to start a new post for the fan or running hot in park issue. We need to try and keep each post to one issue so that it is easier for others that may have the same issue as you.
Due to the A/C blowing hot after just a few minutes we can assume you have a pretty large leak. Your AC system or the cans that you put in should have had dye in them. Due to this, you should have dye somewhere along the AC system. Either a joint in a line or one of the components is leaking causing your issue. If the mechanic said it is the compressor leaking then unfortunately it will need to be replaced in order to fix it.
https://www.2carpros.com/articles/air-conditioner-leak-detection
Let me know what you find after reviewing this guide. Thanks
May 23, 2020 at 11:57 AM
