A/C not cooling, error code 1426
167,000 MILES • 5.8L • V12 • 2WD • AUTOMATIC
RAMZITH1
  • 83 POSTS
Recently my car A/C is not cooling, there is no leaking, gas is full, checked for errors found error 1426, I deleted the error but still not cooling, again the same error show up every time I erase it, so please help, thanks
RAMZI
Apr 20, 2021 at 6:11 AM
  • 110,251 POSTS
The code doesn't seem related to the A/C. It is related to the fuel tank vent valve being stuck open.
As far as the A/C, check to see if there is power to the compressor clutch. The clutch itself may have failed. Also, are you certain the Freon is full? Low pressure will prevent it from turning on as well.
Take a look through this link and let me know if it helps:
Apr 21, 2021 at 12:19 PM
RAMZITH1
  • 83 POSTS
Will check and revert back to you. thanks
Apr 23, 2021 at 10:14 AM
  • 110,251 POSTS
Happy to help. I will watch for your reply. Also, if it is possible, check the static pressure of the system and let me know what it is. Static pressure is when everything is off. If you can, let me know both the high and low-pressure readings.
Apr 23, 2021 at 11:19 AM
