Follow the liquid line back from the condenser to the evaporator. You will see a crimp in the pipe where the tube sits. On many of the Fords you have to replace the entire line because it is in the middle of the metal pipe but a lot are right at the joint. It could even be in the inlet of the evaporator.
Aug 10, 2016 at 9:19 AM
