A/C not cold
230,241 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
RODNEY7867
  • 70 POSTS
Well, i was talking to someone about this. I thought i had it fixed but now it is blowing hot air again. could the switch i got from junk yard be bad again?
Jul 13, 2019 at 11:06 AM
RODNEY7867
  • 70 POSTS
I replaced clutch plate and coil and control panel. I am also thinking maybe leak.
Jul 13, 2019 at 11:39 PM
Hi Rodney,
Let's just start with getting pressures. If you don't have a gauge set as shown in the attached guide then you can just rent them from the local parts stores. Most will do it for free (as long as you return them).
Once we get the pressures we can better determine next steps. Thanks
Jul 13, 2019 at 11:53 PM
