Ac not blowing cold
117,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
JHHBRUIN
There does not seem to be power to the clutch on the A/C compressor. How can I determine what is wrong?
May 18, 2017 at 12:17 AM
STEVE W.
  • 15,409 POSTS
Start at the fuses and clutch relay. The clutch fuse and EGR fuses power the relay. Test the clutch itself as well. Also look at the wiring to the clutch as it grounds to the block and the wire may have corroded off.
Then check the triple pressure switch. If either section of that fails the power to the clutch is cut off. Next check the interior controls.
Do you have a good scan tool that can trigger the clutch? That makes it a lot easier to deal with this system as the clutch is controlled through the PCM and the tool would allow you to check the controls as you select AC.
May 18, 2017 at 12:44 AM
JHHBRUIN
Thanks I will check those.
May 18, 2017 at 1:58 AM
