A/C noisy?
106,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
BAT KID
  • 48 POSTS
Whenever the A/C or defroster is on and the transmission idling in drive it makes a loud chirping. When I'm driving it's quiet but when i come to a stop and it idles it chirps bad. If you put it in park and the A/C or defroster is on its quiet. Being the a compressor engaged i figured the tensioner wasn't strong enough to handle the load so i replaced the belt tensioner and the chirp still exists. So, when it's in drive and idling and the air on is the only time it acts up. If you rev it up it goes away or if you turn the A/C off, it stops. Would you expect a component of the A/C compressor is failing? Also, the belt was replaced 10,000 miles ago when I changed the timing belt. I'm just confused as to why it happens only in drive with the air on and in park with the air on its quiet.
Sep 17, 2022 at 4:05 AM
  • 110,251 POSTS
Is it possible for you to record and upload it for me to hear? I realize the belt isn't old, but what you described sounds like a belt noise. The A/C compressor places a heavy load on the belt. Also, when the defroster is on, the compressor engages.
Sep 17, 2022 at 4:06 PM
BAT KID
  • 48 POSTS
At the 22 second mark you can hear the belt chirp and also a rattling noise as well. Like i said, it only does it when i come to a stop. i can sit in park and it's fine or driving its fine it's only when I'm at a complete stop in drive. in the 2nd video i have it in drive and foot on the brake and just tapping the gas i can make it do that noise.
Sep 19, 2022 at 11:25 PM
  • 110,251 POSTS
For some reason, I don't have the time stamp at the bottom of the video. I did listen to both videos several times but didn't hear a chirping noise. I do hear something that sounds like it's vibrating.
If you have a helper start it and place it in gear, open the hood and see if it is louder and upload it for me to hear.
Sep 20, 2022 at 11:12 AM
BAT KID
  • 48 POSTS
In this video you can really hear it and you can see the tensioner moving. I replaced the belt 15,000 miles ago and the tensioner was replaced a few months ago. Both are Ac Delco parts and i changed the tensioner because i figured it wasn't strong enough to hold tension under the load of the compressor when it was engaged but the new tensioner didn't solve the issue. I'm not sure if the Ac Delco design isn't good enough? These 1.8 tensioners are different than the 1.4 turbo tensioners.
Jul 12, 2023 at 4:36 AM
BAT KID
  • 48 POSTS
In this video you can hear it happen in reverse or drive but not in park or neutral.
Jul 12, 2023 at 4:39 AM
  • 110,251 POSTS
It sounds like the belt. Try this. When it is making the noise, pour a small amount of water on the belt and see if it stops or changes.
Jul 12, 2023 at 4:14 PM
BAT KID
  • 48 POSTS
Alright i sprayed the belt with water and there was no change but i had my wife help me and with the ac on and in drive you can in this video I'm attaching the belt starts to vibrate like crazy and the chirp is the belt because it vibrates due to lack of full tension when it's under the load of the compressor. I changed the tensioner 4,000 miles ago with the ACDelco OEM tensioner. In the video when it starts chirping bad you can see the belt vibrating like its losing tension.
Jul 13, 2023 at 7:52 AM
BAT KID
  • 48 POSTS
Here's the video:
Jul 13, 2023 at 8:01 AM
  • 110,251 POSTS
It could be the belt, the tensioner, or the compressor. Has anyone added Freon to it recently? If it is overcharged, this can happen. However, I did notice the belt tensioner in an earlier video you sent jumping around. Also, is this the correct one for the vehicle? The OEM part number should be 25191534.
Jul 13, 2023 at 9:12 AM
BAT KID
  • 48 POSTS
No, i have never added Freon to it for the years I've owned it and yes, the tensioner is jumping but it's just strange how i changed the tensioner and that never fixed the issue it still had the same problem. Yes, that part number is the tensioner i installed.
Jul 13, 2023 at 9:26 AM
BAT KID
  • 48 POSTS
With the car running and A/C on i pull the oil dipstick out and I hear a hissing in the back of the engine and then it triggers the engine to struggle and the chirping. With the A/C off and dipstick pulled it'll do the same hiss and engine hesitation but no belt chirp. I don't know if that means anything more or just shows that's a load on the engine like a compressor creates.
Jul 13, 2023 at 10:44 AM
  • 110,251 POSTS
This keeps getting more and more interesting. Is the PCV in good condition? I'm going to ask the site owner for his input. He is excellent with A/C, and since that is where we started, I want to see what he says.
Jul 13, 2023 at 12:19 PM
BAT KID
  • 48 POSTS
I haven't checked the PCV valve so I'm not sure, but i can say i haven't had any issues other than this A/C issue and alright sounds good. thank you
Jul 13, 2023 at 12:31 PM
  • 110,251 POSTS
I suggested the PCV because when you remove the dipstick, the sound returned. It seems like that is lowering the RPMs and causing the noise. It's just a theory. When you remove the dipstick, it is allowing fresh air to enter the crankcase. With the dipstick removed, is there a strong vacuum at the dipstick tube?
Jul 13, 2023 at 2:48 PM
BAT KID
  • 48 POSTS
Makes sense and yes, i pulled the dipstick and put my finger over the hole and felt suction on my finger.
Jul 13, 2023 at 9:14 PM
  • 55,837 POSTS
Yep, this happens when the valve cover needs to be replaced because the crankcase ventilation diaphragm has gone bad and creates an internal vacuum leak inside the engine. Here is how the job is done to fix the problem. Check out the images (below). Please let us know how it goes.
Jul 14, 2023 at 2:09 AM
BAT KID
  • 48 POSTS
I know the 1.4turbo is known for the valve cover diaphragms going bad but didn't think the 1.8 would have that issue but if that diaphragm went bad in my valve cover, then would the issue happen all the time vs only when the A/C or defrost is on? I replaced the valve cover and gasket the end of April 2020 because there was an oil leak from the gasket and i used GM parts.
Jul 14, 2023 at 5:02 AM
  • 55,837 POSTS
The problems you are having are the same as a car we had in the shop, when you replaced the valve cover did it have the diaphragm in it? You may have a defective unit.
Jul 15, 2023 at 3:17 AM
BAT KID
  • 48 POSTS
I'm not sure it was 3 years ago but I'll buy a new cover and let you know how i make out. Thank you to both of you for your help so far in this issue, I appreciate it.
Jul 15, 2023 at 3:23 AM
BAT KID
  • 48 POSTS
I just installed the new valve cover GM #55564395(new part #96889998), and the issue still exists unfortunately. I am attaching 2 videos.
Jul 19, 2023 at 9:39 AM
BAT KID
  • 48 POSTS
Today at the shop we saw the tensioner bouncing causing the belt to shake and squeal so we took a socket and ratchet and gave the tensioner a little more tension on the belt and turned the A/C on and put it in drive and even tapped the gas. It stops when you give the tensioner more tension so i guess the new tensioner i put on it months ago is defective. and or the new belt i put on months ago before then is stretched? Both are ACDelco OEM parts so I'm kind of confused but i guess I should change them again or warranty them out or try different brands?
Jul 20, 2023 at 12:19 AM
BAT KID
  • 48 POSTS
Problem solved. i had an ACDelco 6k609 belt on it because rockauto said it works with A/C. I looked up on Chevrolet parts website and it calls for a gm55578115. Rockauto doesn't show that number as a cross reference when you select the 6k609. I bought a continental 4060610 which crossed to that 55578115….Delco 6k609 says its 61 1/2” and the 55578115 says its 61” so i guess i had the wrong belt on my car and I'm not sure why rockauto lists it as an option or why there is 2 different sizes that close in range for a with A/C option.
Jul 20, 2023 at 3:13 AM
  • 110,251 POSTS
I have a feeling it was the belt. That was my first thought above. And I can only imagine how frustrated you are after all you've done.
Regardless, I'm really glad to know you got it fixed. Take care and please feel free to come back anytime in the future.
Jul 20, 2023 at 11:23 AM
