A/C mode issue only on defrost?
134,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
STXHAMMER
  • 47 POSTS
Hey, my A/C and heat work in the car but only on defrost. It seems the mode no matter what I select only comes out the defrost. Is it the blend door actuator which I think is located behind the glovebox or someone else?
Jul 30, 2025 at 1:43 PM
  • 55,694 POSTS
So there are two systems, one for the manual system which is vacuum operated, if this is the system you have I would look under the hood for the small vacuum line (plastic) headed from the vacuum reservoir to the engine and then to the firewall, please go over this guide to see what I am talking about.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
If you have the "auto" system the problem will be the mode door actuator, here is the location for that, please let me know which system you have. Check out the images (below). Let us know how it goes.
Jul 31, 2025 at 4:19 AM
STXHAMMER
  • 47 POSTS
I have the manual one I believe. I will check it out and report back. Thank you
Jul 31, 2025 at 10:50 AM
  • 55,694 POSTS
Okay them manual one is vacuum operated, check the small tube under the hood like the guide shows. Have a good weekend!
Aug 1, 2025 at 4:38 AM
