AC mode is not working
200,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MUTHUKUMAR
The A/C blows only cold air and only through middle vent but not in defrost vent and lower vent. I could feel little heat if it is in 85 degrees Fahrenheit.
Sep 25, 2018 at 8:00 AM
  • 110,248 POSTS
Before I get started, I need to confirm something. You mentioned potentially two different issues. I need to know if the problem is temperature related or if it is mode related (air flow does not change).
In general, here are a couple links to review to help you determine what is actually happening:
https://www.2carpros.com/articles/car-heater-not-working
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
If possible, look through those links and let me know which is closest related to your problem.
Sep 26, 2018 at 11:15 AM
