AC low pressure sensor
95,000 MILES • 3.4L • 6 CYL • 2WD • MANUAL
JRYZNIC
Dose my truck have a low press sensor? I do not see one anywhere.
Jul 3, 2018 at 3:24 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Are you asking if there is a system cut-off switch? There is a compressor cut-off switch that will shut the A/C system off when it is detected the system is low on refrigerant. It does this to keep the A/C compressor from cycling to keep from causing damage. After the system is recharged to proper specifications the system will work again. Hope this helps and feel free to ask any further questions. Danny-
Jul 3, 2018 at 9:58 AM
JRYZNIC
Advice was helpful. Can you tell me where the cut off switch is located?
Jul 4, 2018 at 7:01 AM
DANNY L
  • 5,648 POSTS
Hello again.
Here is a picture attached (underhood passenger side). Hope this helps! Thanks again for using 2CarPros and let me know if you have any other questions!
Danny-
Jul 4, 2018 at 10:01 AM
