A/C leaks
158,000 MILES • 6 CYL
GMAURICE
air conditioner not cooling.
Sep 30, 2020 at 2:24 PM
Is there a reason that you think there is a leak? Have you checked the pressures to find out if the system is empty? There could be an electrical issue, sensor issue, or compressor issue causing it to not operate. Here is a guide that will help with that:
Let's start with this info and go from there.
Oct 1, 2020 at 10:42 AM
