Leaking water when the A/C is on under the car?
117,000 MILES • 4 CYL • 2WD • AUTOMATIC
BOSTONBRAWLER92
  • 6 POSTS
The leak is a little more than a small puddle, is this normal? I verified that the leak was water and not coolant and only leaks when the A/C is on.
Jun 7, 2023 at 5:37 AM
  • 55,688 POSTS
Yes, this is normal especially in humid weather. The leak is on the passenger's side of the car correct? If so you have nothing to worry about. Use 2CarPros anytime, we are here to help. Please tell a friend.
Jun 7, 2023 at 8:45 AM
