A/C issues
170,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
ROB PEEBLES
  • 12 POSTS
I recently replaced the compressor, accumulator and orifice tube. I had the system flushed and filled. the clutch on the compressor engages when the A/C is turned on, but does not cycle. The pressure on the low side seems high (150), and the high side seems low (also about 175).
Jul 19, 2020 at 6:55 AM
Good afternoon,
Is the clutch engaged with those readings?
If it is, the compressor is bad.
If it is not then we need to find out why the compressor is not engaging.
I attached a wiring diagram and the location of the relay if we need to do testing.
Jul 19, 2020 at 7:30 AM
ROB PEEBLES
  • 12 POSTS
The clutch does not disengage unless the system is turned off.
Jul 19, 2020 at 7:34 AM
It should only engage with the engine running and the A/C commanded on.
Can you explain what you mean?
Jul 19, 2020 at 7:36 AM
ROB PEEBLES
  • 12 POSTS
Also, cold air blows from the passenger side, but cool blows from the driver's side. The lines in/out of the dryer are cold and have condensation, and the lines around the high pressure port are very hot to the touch.
ROB PEEBLES
  • 12 POSTS
it engages when the system is on, and disengages when the system is off, but it does not cycle when the system is on. I expect the clutch to engage and disengage as the sensors monitor the flow of refrigerant.
Jul 19, 2020 at 7:38 AM
The readings you gave me show that either the compressor is bad or the system is not on.
Can you recheck those pressure readings with the A/C on and the engine running?
Jul 19, 2020 at 7:51 AM
ROB PEEBLES
  • 12 POSTS
Okay, reconnected and tested the pressures with the gauges closed this time (rolls eyes). 40 low, 225 high, about 85 degrees ambient.
Jul 19, 2020 at 8:27 AM
Okay, they are both a little high.
The high side should be 2 times ambient plus 15%.
The low should be 25-30 rock solid.
Looks like it is overcharged.
Jul 19, 2020 at 8:42 AM
ROB PEEBLES
  • 12 POSTS
bled off pressure as indicated, no change.
Clarification, pressures are now 30/195, no change in cooling.
Jul 19, 2020 at 9:17 AM
Did you take it for ride and see if it cools down?
What is the duct temperature?
Jul 19, 2020 at 9:28 AM
ROB PEEBLES
  • 12 POSTS
idling it's cool, driving above about 30 it gets warm. don't have a vent temperature thermometer.
Jul 19, 2020 at 9:30 AM
How much Freon did you install and how long did you vacuum the system?
Did you add any oil?
Jul 19, 2020 at 9:33 AM
ROB PEEBLES
  • 12 POSTS
I had a mechanic do it. When i replaced the compressor, it came with oil, then I added about 3oz. I slept on it and realized it was too much oil so I paid to have it flushed and filled.
Jul 19, 2020 at 9:36 AM
Did you add the oil to the Freon side or into the compressor?
Jul 19, 2020 at 9:37 AM
ROB PEEBLES
  • 12 POSTS
I added by way of suction into both high and low pressure port. I drew a vacuum then let the vacuum suck it in through a tube from bottle to port.
Jul 19, 2020 at 9:42 AM
Okay, 3 ounces was good to add for what you replaced.
How long did you vacuum the system?
Jul 19, 2020 at 9:44 AM
ROB PEEBLES
  • 12 POSTS
i brought it down to -5 and held it there for about 10 minutes. then closed off the vacuum and made sure it held -5 for about 5 minutes.
Jul 19, 2020 at 9:46 AM
No, it needs to pull 30 for at least 45 minutes to boil all the moisture out. Then add the exact amount of Freon called for.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jul 19, 2020 at 9:48 AM
ROB PEEBLES
  • 12 POSTS
I had it redone by a mechanic after I did it.
Jul 19, 2020 at 9:50 AM
Okay, hopefully he did it right. From the readings, it is either too much or moisture in the system.
Your pressures came down but bleeding it off is the wrong way to do it.
If he added the correct amount then now you are low in Freon.
Jul 19, 2020 at 9:57 AM
ROB PEEBLES
  • 12 POSTS
I'm not convinced he actually did what I asked for. he said originally it was low on Freon, i'm afraid he just added some and raised the pressure. I had it at 35, but he put it at almost 50. sounds like i need to take it back.
Jul 19, 2020 at 10:00 AM
50 is way high as well as 35. Like I said, it should be 25-30 pounds and rock solid.
Jul 19, 2020 at 10:02 AM
